Crazy Battery Drain - Help!
Old May 6, 2010 | 09:10 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Engine: Carb 350ci bored .40
Axle/Gears: 2.73:1
Ok so my battery to my 91 camaro died in all of about 10 minutes of driving. Drained from a fully charged battery from the previous nite (battery charged at 2A for a couple of days, was unpluged for a day)
I'm assuming the battery just cant hold a charge and plan on getting it checked tommarow but wanted to check if there was any thing that could cause this also.
Old May 7, 2010 | 04:30 AM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: Crazy Battery Drain - Help!
Check the cooling fan fuse the alt wont charge if its blow/missing.
Old May 7, 2010 | 08:55 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Ok cool, will check it when i get back to my house today.
Old May 7, 2010 | 10:45 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Just thought about it, dont know if it matters or not but my fan is on a toggle switch that i threw in earlier. It doesnt nessecarly go thru the fuse box.
Old May 10, 2010 | 11:33 AM
NIN's Avatar
NIN
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Ruse
Heres how you can tell:
Turn the key to the RUN position.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) see if you have power on the brown wire on the alternator connector.
If you do, the blower fuse is not causing problem.
Happy Racing!
Does The White Flag Mean Hes Surrendering?
Old May 22, 2010 | 03:50 PM
afnunez's Avatar
Re: Fuse Ruse
Happy Racing!
That brown wire has no voltage when I turn key to run. I run my fans off a toggle switch. The two relays that run the fans are completly out. Is there a way to work around that? So I can get the alternator to charge the battery?
Old May 25, 2010 | 09:56 AM
NIN's Avatar
NIN
Transmission: 765R4
Fuse Ruse
Connect the brown wire to any hot in run circuit.
Happy Racing!
I Didnt Wreck, The Track Moved
Old Oct 19, 2010 | 02:56 AM
pjp209's Avatar
Car: Gone
same prob with my bros 89 rs wont hold a charge new batt alt is good fan is hooked up to ac.any help
Old Oct 19, 2010 | 08:46 AM
NIN's Avatar
NIN
Transmission: 765R4
Drain Pain
Sometimes the under-hood or hatch light does not go out so check those easy ones first.
Then connect an ammeter in series with the battery.
If there is more than 50 milliamps there is excessive draw.
(You can use a small bulb such as a side marker bulb if you dont have an ammeter.)
Disconnect the alternator wires to see if its the problem.
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time, including the pump fuse near the battery, till you see the current drop.
Thats the circuit with the problem.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 22, 2010 | 02:54 AM
pjp209's Avatar
Car: Gone
it was the battery needed to be charged it sat for 4weeks thanks guys
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
