Fuse Keeps Blowing
Old May 7, 2010 | 09:55 AM
Usd2BAFORDGUY's Avatar
Fuse Keeps Blowing
Just tossing this out here since I have no Idea where to start. 87 Formula. Flip the headlight switch on and the lights go up and on and the fuse for the tailights blows out. Which also leaves the headlights in the up position even after I shut it off. I put a new fuse in with the switch in the off position and bang. The lights go back down. I have replaced the switch but that does not correct the issue. Everything was working fine and then one night it started out of the blue. Should I start looking at the tailight wiring? Or the headlight motor wiring. Headlight motors have been rebuilt a few months ago so they work fine.
Any tips are well appreciated.
Sean
Old May 7, 2010 | 10:10 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Fuse Keeps Blowing
I would check the whole circuit for a short to ground, remember when you turn on either the parking lights or headlights the tail lights also come on, look behind the lights for any bad wiring or issues to start.
Old May 7, 2010 | 12:21 PM
Thanks Kevin. I will start at the source I guess
Old May 11, 2010 | 09:37 AM
Just a quick update on this guys. After tracing wires in the hatch area with no luck. I did some more searching on the boardsand found a few other members having issue with the radio wiring. Well yeah. Thats what it turned out to be. Guessing I should have used the search feature a little better but lesson learned.
Sean
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
