87 TA eye's won't shut D:
Old May 10, 2010 | 05:36 PM
brucec89's Avatar
Car: 87 Trans AM GTA
hey guys, my 87 TA's eyes won't shut after i turn them off(stuck in up position). i checked the motor and turns out the driver side motor is gone and probably the guide is gone too. After i put in a "new" used guide and a motor they are still not cooperating. My old guide can only make them go up, but won't shut it and the "new" one can only shut it once i connect the wires and that's about it. Please help
Old May 10, 2010 | 11:18 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
Re: 87 TA eye's won't shut D:
sounds like it could be a couple things, either your headlight switch is bad, and doesnt recognize that they are supposed to go down after turning off, or your headligth relay has gone bad. there may be some other possibilities from others who know more about it than I do, but those would be my guesses.
Old May 10, 2010 | 11:56 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
The headlight motor control unit is on the firewall,it might be part of the problem.If you know that the headlight motors work 100% then I would start looking at the control module..of the headlight switch itself.
First get yourself a battery ..drill battery works great,unplug the headlight motors.Take 2 pieces of wire and plug it into the headlight motor directly and the other end connect each wire to the battery terminals.It will power the motor up or down,then reverse the wires and try again ..this will show you if the motors are in working order and eliminate that issue.
Second easiest thing to check is the headlight switch in the dash with a multimeter or testlight.If that checks out good then move to the control module and check that the signal from the switch is working as it should at the module itself.If that is still good then you know you need the module.
All else fails..manually turn the headlights down with the **** on the motors directly..it sucks but thats why they are there incase of emergency :S
Old May 11, 2010 | 12:19 AM
brucec89's Avatar
k here's where i stand now...
the motor is perfectly fine, checked them over today.
the guide i mentioned is the module... right now i have 2 on my hand, the original can only make them go up, not down. the "new" one makes the lights go down once i connect the wires to the module itself, it doesn't do anything after that...
Old May 12, 2010 | 08:37 PM
brucec89's Avatar
k it's fixed now. turned out the connecter to the switch was burnt and the module/guide was gone. thanks guys
Gunner242
Dec 25, 2015 04:49 PM
86IROC112
Nov 7, 2015 06:50 AM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
