Need 1987 hatch pull down wiring diagrams
Old May 12, 2010 | 09:42 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i have a diagram for a 1988 + pull down but the pull down i have is from a 1987 car and the wiring is different then shown. anyone have a scan of the diagram? thanks
Old May 14, 2010 | 05:31 PM
FueledSoul's Avatar
Re: Need 1987 hatch pull down wiring diagrams
bump. i have a 1988 book with wiring diagrams and it show 3 wires going to the relay but my pull down from a 1987 has 4 wires going to the relay one is white and i dont know what its for. can someone scann and post a 1987 pull down wiring diagram thanks
Old May 14, 2010 | 05:58 PM
Twin_Turbo's Avatar
I have a factory service manual, I could take a pic.
However, what do you want to know? I just wired mine up (also 87)
Old May 15, 2010 | 09:40 AM
FueledSoul's Avatar
just the hatch pull down and hatch release wiring diagram
Old May 15, 2010 | 10:56 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
An 87 diagram would be nice to have when I start playing with mine. I remember looking at my friends 89 and saying "What the ****!" while I was trying to get it to work. lol. Adam :-)
Old May 16, 2010 | 03:16 PM
aldaran's Avatar
Do you have a cargo light in the hatch area? If not, then the wire doesn't go anywhere (extra) if so, it plugs to the cargo light. I fixed mine years ago, and I was wondering what the wire was for. I didn't have the cargo light in the hatch area.
Old May 16, 2010 | 03:47 PM
FueledSoul's Avatar
i still need a diagram. the car im putting it in never had a pulled down i still dont know where the wires are that pop the hatch.
Old May 17, 2010 | 06:51 PM
aldaran's Avatar
It's a 2 part system. One system pulls down the hatch which uses the relay. The second system uses an actuator that pops the trunk. I'll check to see if I have a wiring diagram for them. I thought 87 and 88 had the same system.
Old May 18, 2010 | 09:43 PM
FueledSoul's Avatar
sweet, yea i thought they where to but apparently not
Old May 19, 2010 | 04:17 AM
Twin_Turbo's Avatar
They are the same, only the wire coding is different over the years. There's 1 wire that may not be used, it's a short section w a black connector 9single wire), it's the switched ground (internally switched) for the cargo light so that it comes on when the trunk is popped open.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
madsv1000
Aug 20, 2015 06:45 AM
jahblah
Aug 12, 2015 05:54 PM
