baker electronics vats help
Old May 15, 2010 | 01:14 AM
jburton50's Avatar
ok, itsd kinda late but i rly need some help, i jsut got my vats bypass for my 91 camaro, now, WHERE THE HELL DO I HOOK IT? its got 3 wires, ones groung (ok simple) ones to the switch (ok.. to the thick yellow one under the steering column, or the one in the pass. side kick panel or what??), and the other is to the fuel pump enable wire? im lost can anyone help?
Old May 15, 2010 | 09:19 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: baker electronics vats help
Usually the way those work is, one wire goes to a switched power source, one to ground, and the 3rd goes to the vats wire on the computer wiring harness. It should be a dark blue wire.
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
MrPackstin
Oct 25, 2017 08:09 PM
anesthes
Sep 30, 2015 07:48 AM
AmorgetRS
Sep 28, 2015 09:33 PM
