Do the foglights have a relay ?
Old May 16, 2010 | 09:45 PM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
As the title says . If so where is it ? foglights just stopped working after I painted my engine bay . I did remove a few relays and ground but I put them all back in place . Any help would be great . Thanks
Old May 17, 2010 | 09:55 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Driving In London
The fog lamp relay is located about a foot behind the assembly line diagnostic link.
Happy Racing!
Why Did They Say I Was Speeding In The Pits? There’s No Speed Limit Sign.
Old May 18, 2010 | 12:52 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Do the foglights have a relay ?
Hello Roc THIS!!
The fog lamp relay according to the 1987 service manual is located right in front of the windshield washer tank, on the fender. On my 1987 IROC that's where it's located, and my 1987 Z-28 doesn't have the fog lights, and it's also missing this relay, that's supposed to be located right in front of the windshield washer tank!!
P.S. It's a square BOSCH relay!!
Old May 18, 2010 | 11:41 PM
Roc THIS's Avatar
Engine: 5.7 TPI
The relay was right there and that was the problem . Bad relay caused the fuse to blow . You guys saved me again . Thanks guys
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
