Derale Electric Fan Trouble
Old May 22, 2010 | 02:15 PM
Joes1wood's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
I have a 16 inch Derale Electric fan. It's set up with a temp sensor and relay so it will turn on automatically at 185 and shut at 170.
The car cranks and starts with the touch of the key when its cold/below 185. But when I try and start it with the temp over 185, slow cranking & doesn't run as well. Any suggestions for mistaken wiring or something?
Old May 23, 2010 | 04:37 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Derale Electric Fan Trouble
Do you have headers? Or a different starter? if so you may be getting heat soak on the starter, causing it to perform worse once hot.
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
