92 rs turning signal issue
Old May 22, 2010 | 10:06 PM
t-ray10's Avatar
Car: 1992 Camaro RS, 2012 ZL1 on order
Engine: 5.0 305, 6.2 Liter LSA SC
Transmission: T5, TR6060
Axle/Gears: stock, 3.73
I have a 92 rs with tbi 5.0. I had to replace the key switch which resulted in me moving the turn signal equipment a little bit. I put everything back together and now only the left turn signal works. The right turn signal stays on in the back and has no power going to it in the front. There is also no turn signal on the dash and the signal stat does make noise on the left but not the right. please help.
Old May 22, 2010 | 10:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 rs turning signal issue
Before I tore into the steering column again - I'd replace the bulbs on the bad side just to see.
Old Jun 23, 2010 | 02:07 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What camaronewbie said.
If you still have trouble, acces the main connector at the base of the column and check for power, key on, at the dark blue wire(right front signal) while cycling the switch. Then check for power at the dark green wire(right rear signal) while cycling the switch. If the dark blue wire doesnt have power and the dark green wire always has power, go back into the column and check out the switch for broken wires or contacts.
Old Jun 25, 2010 | 10:54 PM
t-ray10's Avatar
I finally figured it out, the wire that goes to the connector had come out and hidden itself in the rest of the wires
Old Jun 26, 2010 | 12:15 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Right on.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
