What are these wires??
Old May 24, 2010 | 08:26 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
I just put the dash back in this car (i didnt take it out PO did) i have these 2 plugs that i cant find where they go. The car is a 92 camaro. I have the wires pulled behind where they ac controls are but that my not be where they go. Any help?
Old May 24, 2010 | 09:27 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: What are these wires??
The back and white one looks to be the VATS plug. It should plug into a connector with the same color wires at the base of the steering column. The other one, I have no idea about.
Old May 24, 2010 | 09:44 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I believe the bigger plug is for the interior lights on the AC controls. Not sure about the smaller one
Old May 25, 2010 | 05:34 PM
Transmission: autos
the ac controls are all plugged up so cant go there. Anymore ideas anyone?
Old May 25, 2010 | 06:34 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
Engine: ewww...the 3.1L
Transmission: Not sure. It shifts quite hard.
Axle/Gears: 3.23 8.75" 10 bolt
do you have dash lights? if not the larger one may be for that. I am sorta in the same boat except the connectors were cut off.
Old May 25, 2010 | 07:07 PM
Transmission: autos
u know what. Thats what it is, i do have that little dash light in the garage somewhere. I searched all over for that little plugs home and i cant find it anywhere.
Old May 25, 2010 | 10:22 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
not totally sure where it goes. probably under the dash near the instrument panel. I cant tear apart my car yet....fuel tank recall work in the mix.
Old May 26, 2010 | 07:23 PM
Transmission: autos
it goes under the dash pad kinda under the left center ac vent. I might wire mine in if i can located the light.
Old May 26, 2010 | 09:36 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
thanks for the info. if you find the easy way to get to it, i wouldn't mind knowing also!
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
