rewiring intank fuel pump
Old May 25, 2010 | 02:36 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i recently swapped carbs from a q-jet to a holly. in that process i removed a lot of wiring from the engine bay. i removed 6 relays and later found out that one of them is for the intank pump. i have a picture of them in an album in my profile. if someone could point out which one is for the fuel pump that would be great.
my main goal is to rewire the pump so it works without wiring it to the computer. so i started digging for the wires that go to the fuel tank area and this is where im at.
ok, i found 3 wires coming from the fuel tank.
a black one that is grounded below the back seat.
a pink one that im assuming is power
a tan one that might be to the fuel gauge?
would that make sence for a float style fuel gauge?
also would it be possible to rewire this without the relay? i was thinking of connecting the power to the fuse box. anyone have any ideas.
Old May 25, 2010 | 04:30 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: rewiring intank fuel pump
You can wire a simple relay using the original wires. The relay will have the following wires - PPL or GRY is power to the pump, BLK is the ground, ORN is power, and DK/GRN is the signal wire. The simplest way to do this is keep the battery power and run ignition power to the enable wire. Run the FP enable wire to the pump and run the ground wire through a switch, or whatever you want to use.
Also, your intank pump will literally blow the carb seals with gas. It is way too much pressure for a carb without going through a huge pressure decrease. You would be better off pulling the pump and going with mechanical or aftermarket low pressure pump.
Old May 25, 2010 | 05:02 PM
TNT_Z28's Avatar
the car is a 1987 lg4 car that came factory with 2 pumps. 1 in the tank and 1 on the block.
also, there are only 3 wires coming from the pump. one ground(black) one is pink and the other is tan. does the pump need a relay or can i just connect it to the ignition power on the fuse box?
Old May 25, 2010 | 05:21 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Do you guys know where the wires run once they go inside at the back seat? Right now my pump is wired to run all the time when the ignition is on but I need to route it so the ECM triggers the relay. The car's been hacked on so I can't even find where the relay is anymore. I also have an '87 that was originally an LG4.
Old May 25, 2010 | 06:07 PM
TNT_Z28's Avatar
as far as i can tell the wires go through the body behind the back seat and then to the top the the fuel tank. probably where the pickup is at. check and see where your pink and tan wires run to(such as a relay or fuse box) and let me know.
Old May 25, 2010 | 08:28 PM
Car: '87 Camaro LT
Engine: 355 L98
That's the part I'm trying to figure out... where they run to inside the car. Down the right side, or left side? And where they come out.
Old May 25, 2010 | 08:31 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
I THINK it's this one (circled on the driver side firewall, above the c100). My cars harness was hacked, hence my swap to an LT1. This one has the closest colors if i remember right. Even if it isn't this one, the wires run down the passenger side of the car, up threw the fender well.
Old May 25, 2010 | 10:07 PM
TNT_Z28's Avatar
thats the cooling fan relay. thats the only one relocated and left in the car.
Old Jun 1, 2010 | 11:22 AM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I been doing an LT1 SWAP and cut and removed the tpi wire harness on a 86 iroc, I am using the lt1 engine wire harness , I thought I had my relay connect right but when i turn the key on there no fuel pressure I think my fuel relay is not connected right the five wires on my relay Orange -power dark green goes to PCM ? tan/white to tan wire on fuel pump ? black is ground and redwire goes where?ignition on ? isthis right thanks for your help email is brioneschevybelair@yahoo.com A -red B -black/white C-Tan/white D-dark Green E-Orange
Old Jun 1, 2010 | 01:35 PM
55ChevyMan's Avatar
fuel pump relay does tan/white wire go to the fuel pump tan wire?
Old Jun 1, 2010 | 01:51 PM
TNT_Z28's Avatar
idk. what i did is this.
i cut the tan wire from the tank right by my clutch pedal. i then bought a simple relay from o'reillys. i mounted the relay right behind the lever that pops the hood open.
i ran a six inch wire from the ignition port in the fuse box to the relay. i connected the cut (tan) wire opposite of the ingition wire.
then i spliced into the power wire from the battery to the computer, (in my case it was an orange wire) using a Y connector. i ran a wire from there through the firewall and to a port on the relay.
then i connected a ground wire opposite of the battery power i just connected.
this seems to work fine. every time i turn on the ignition, the pump starts to flow fuel. i hope this helps.
Old Jun 1, 2010 | 01:53 PM
1981LT1's Avatar
Engine: LT1; LT1
The wires are routed along the driver rocker panel and connect behind the driver kick panel. The purple (or pink) is the gauge wire, the tan/white is the pump power and the black is ground. The relay will have an orange (battery), green/white (ECM signal), black (ground), and pink (ignition). If there is a red wire, it is most likely a field service enable, which will energize the pump when power is applied directly to the red wire.
Old Jun 2, 2010 | 11:22 AM
55ChevyMan's Avatar
onmy 86 iroc fuel pump relay A - wire is red B -wire black/white C-tan/white D- dark green E -Orange but here on 86Camaro TPI V8 VIN F A-wire Diagrams A- wire tan/white B- black/white (C- green/white goes to ignition) D wire starts Orange then red/black Ithink this would go Pcm E-wire is Orange (hot at all times) were the 85 FUEL RELAY WIRES deferent than the 86 on the Holley fuel pump relay kitt it only has four wires no wire for the pcm I am doing Lt 1 swap
Old Jun 3, 2010 | 12:13 PM
55ChevyMan's Avatar
well it seem I had the wrong connector it wasnt the fuel relay connector and TPI Parts sent me an email that said the 94lt1 stand alone wire harness has a fuel relay connector already in it, my harness is a stock 94crovette lt1 harness would it have the fuel relay connector in it??????? help I dont think so
Old Jun 3, 2010 | 12:19 PM
55ChevyMan's Avatar
does the the stock lt1 wire harness already have a fuel relay connector ?
Old Jun 6, 2010 | 06:15 PM
55ChevyMan's Avatar
hope you can help me I looked at the 86 Camaro wire diagram for fuel relay( A tan/white) wire goes to tan fuel pump wire( B is black wire ground) (C green/white wire is Ignition hot when you turn key on only( D is Orange wire )it goes to ALCL CONNECTOR I spliced this to A7 on red PCM connector (E is thick Orange wire this hot at all times ) I used a test light on E its hot at all times C is hot when you turn key on (A) there nothing I think that when ignition is turn on this should be hot ? cause this is going to fuel pump right ? and (B black )it also hot I was using the old 86 fuel relay and later got new one and its the same thing I doing a lt1 swap into a 86 IROC Z Thanks for your help A B C D E are letters 5 wires on black fuel relay connector
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
