No Change Btwn A/C, Vent,Bi-Level, Deforst, Heat Help Please, is it a Vaccum Issue?
Old Jun 6, 2010 | 01:36 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Please help, my HVAC will not switch between the different settings. I guess its vaccum issue.
Also what does this mean. I assume this unit has already been switched over to R-134A. Is there a way to tell besides the sticker becauseI am ready to get this thing going.
Attached Thumbnails No Change Btwn A/C, Vent,Bi-Level, Deforst, Heat Help Please, is it a Vaccum Issue?-ac-part.jpg
Old Jun 7, 2010 | 11:53 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Kewl Newz
Yes it is most likely the vacuum hose became disconnected, pinched, split, etcetera.
The label is telling you the accumulator is good for 12 and 134.
It takes test equipment to determine which gas is in it.
A well equipped repair shop can tell you.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jun 8, 2010 | 12:17 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Kewl Newz
I'm sure it's still R-12. As most people who have tried to retrofit r-134 know, r-134 doesn't work well on the small evaporator and condensors we have. The different vapor pressures and relative boiling/condensing temperatures make it less efficient than r-12. Just check the valves, if they're standard valves, it's r-12. If it's got a funky valve/fitting on top of it, it's prob a retrofit. If you have the time/money, go for r-406a. It's as (if not more) efficient than r-12, and similar ratings on environmentally friendly as r-134a. It's cost is around the same as 134, and it requires mineral oil similar to r-12 (instead of PAG)
As for the vacuum issue, like NINA said, it's probably a disconnected line. Two lines come out around the blower housing. If both are connected to a reliable vacuum source, take your HVAC pannel and see if you're getting vacuum all the way down to the selector. If you are, replace your selector (or fix it, there's a thread on here somewhere).
Old Jun 8, 2010 | 02:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Kewl Newz
Check line from intake to one way valve to interior controls ( valve often cracks with heat or vac line gets broken while working on engine )
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
