engine problems
Old Jun 8, 2010 | 02:53 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
engine problems
went out today and got more gas and installed my new heater control valve and turned the key, nothing, so i just the battery on charge and still nothing, yesterday i moved my alturnator wire and when it touched metal i got alot of sparks, well onto the real story, i have no gauge lights, but i have new warnings on now, i have my check engine soon light on, my infl reset light is on now and my security light is now on, also when i turn on the key my temp gauge burrys its self and my brake light comes on, any help here? my engine is litterally doing NOTHING now
Old Jun 8, 2010 | 03:02 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: engine problems
Sparks usually arent good. Could you have blown a fuse link or fuse? Check for power at your alternator where the big red wire connects. Should have battery voltage. Turn the key on and check for power at the pink wire on your ign coil. Check all fuses. Your VATS system may be having issues but before you get into that, you should check these basics.
Old Jun 8, 2010 | 03:04 PM
Engine: L31 350
Re: engine problems
i thought i blew a fuse but all my fuses are good, i thougt maybe vats but just yesterday i had the engine turning over and fireing, also i might add that when i just the key on my stereo dies.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
