disabling alarm door locks wont work.
Old Jun 8, 2010 | 03:12 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
I had this crappy alarm that came with my car that lights would blink.till i pressed the button like 2 or 3 times then it would be armed and it was just a hassle and crap.SO i just took the connection off from the battery and the power door locks stopped working looks like a hackjob install.The alarm i want to remove looks like the main part of it is strapped to steering column under dash how do i fix this.
Old Jun 9, 2010 | 08:58 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Key Fob Job
Remove the PO hunk of junk.
Now, when you press the door lock switches do you hear the relay click?
If no, use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the orange wires going to lock buttons.
Is there power there?
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jun 11, 2010 | 02:30 PM
C305's Avatar
Car: 91 camaro vert
Re: disabling alarm door locks wont work.
I'm in the middle of doing a swap so nothing is connected at the moment thought it woudl be a good time to just remove what i need to and maybe just rewire completely?
Old Jun 14, 2010 | 02:07 PM
NINÅ's Avatar
Transmission: 765R4
Rewire Attire
I would.
It’s a great opportunity to do a first class job on it with
COLOR coordinated ty-wraps, loom, power status LED’s, etcetera.
Happy Racing!
“I Didn’t Jump The Start, The Flagman Was Late”
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
billybob6110
Sep 23, 2015 01:30 PM
g.l.mos
Aug 22, 2015 12:02 AM
