power windows not working??
Old Jun 9, 2010 | 12:29 AM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
well my friend and i installed a radio into my camaro today and now the windows wont move. I checked the fuses and replaced the relay but nothing seemed to happen. also, my hatch release wasnt working either but i figured out that it works when the e brake is up or the car is off? what else could the problem be? any help is appriciated. thanks.
Old Jun 9, 2010 | 09:09 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window No Go
The widows have a common circuit amp breaker instead of fuses.
Check the breaker for 12 volts in and out.
The breaker is located in the fuse block to the left of the steering column.
If the breaker is OK use a test light
(the type for testing for voltage, not a continuity tester)
or voltmeter to see if you have power at the
pink wire going to the switches.
Is there power there?
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jun 10, 2010 | 12:27 AM
Re: Window No Go
well if the breakers are the metal box things then those are good as well. im getting a voltage tester tomorrow. will check power. is there any way i could just temporarily hard wire them to the battery to get them up? they are stuck in the down position....
Old Jun 10, 2010 | 09:06 AM
NINÅ's Avatar
Transmission: 765R4
Window No Go
To get the left window up ground the brown wire on the left switch and apply power to the dark blue wire.
To get the right window up ground the
tan wire on the right switch and apply power to the light blue wire.
Put a 30 amp fuse in line with the power jumper as a precaution.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Jun 11, 2010 | 12:40 AM
Re: Window No Go
i got it figured out. it was a ground wire that was pulled loose when we pulled the radio out.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
