Firebird headlight motor runs on.
Old Jun 9, 2010 | 02:14 PM
twquick's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.7L
I have a 1992 Firebird Formula that I bought as a basket case. It's nearly back together and I've found a headlight issue. When you hook up the battery, the headlight motors start running and will stop after several seconds (no movement in the lights). When you turn on or off the headlights the motors will run for several seconds after the lights are up or down. When you start the car the motors run for several seconds (no movement in the lights). The lights do go up and down when they are supposed to, just the motors running on concerns me. I'm sure someone has the answer. Thanks.
Old Jun 9, 2010 | 07:38 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Firebird headlight motor runs on.
Bushings are shot, time for a rebuild
TopDownSolutions has a good master kit
Old Jun 9, 2010 | 07:58 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
This is what you are looking for......
http://cgi.ebay.com/ebaymotors/87-92...item335ddc923d
Shop around you should be able to find the kits cheaper without the large gear and just with the 3 plastic bushings....(3 bushing PER headlight), so look for a kit that has 6 bushings! I paid $6.00 CND about 3 years ago.
Good Luck!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
tnrednneck
Aug 13, 2015 08:57 AM
