89 Iroc - Left turn signal Help!!
Old Jun 12, 2010 | 11:40 PM
leedavidalan's Avatar
Hey fellas, my left turn signal has never worked since purchase. However, the other day I had the car totally stripped down because it was gonna get painted. I noticed that the turn signal actually worked briefly, perhaps because some cable or something made contact whereas before it didn't. As of this moment, it doesn't work. Obviously its capable of working, its just that some cable or something needs to make contact with some other component.
Any advice? What color wire am I looking for? Fuse switches?
Thanks guys........
Old Jun 13, 2010 | 06:37 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: 89 Iroc - Left turn signal Help!!
The wire color is light blue.maybe the globe is'nt making proper contact in the socket.
Old Jun 13, 2010 | 07:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might try jiggling nearby wires as well as removing the bulb and cleaning the socket. Swapping bulbs from side to side might be productive.
JamesC
Old Jun 13, 2010 | 08:09 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Check your GROUNDS. 90% of electrical failure is bad grounds.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
