digital dash oil pressure sending unit differance?
Old Jun 17, 2010 | 05:56 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
does anybody know if there is a differance with the oil pressure sending unit on the digital dash trans ams? I just change out my motor in my ta and now my gauge wont read..I had this motor in my iroc and had great oil pressure, now that I put it in my digital dash ta it does'nt even read... any help would be great... thanks
Old Jun 17, 2010 | 07:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: digital dash oil pressure sending unit differance?
Possibly.
Have you tried grounding the OP switch wire at engine to see if gauge still works?
Usually you have to use a sender unit that is compatible with the gauge
Old Jun 17, 2010 | 09:28 PM
Car: 88gta
Engine: 357
Originally Posted by vetteoz
Possibly.
no.. but I will..I had it in my iroc and worked fine,but then when I swapped motors I didnt even think about switching the oil pressure sending unit..I just figured they were the same..
Old Jun 18, 2010 | 12:51 AM
Drew's Avatar
Look up both cars on a parts website like www.rockauto.com and see if they show the same part number.
Old Jun 18, 2010 | 11:25 PM
Car: 88gta
Engine: 357
got it fixed...thanks...and it is the same one..
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
The_Phoenix
Feb 4, 2016 07:10 AM
bamaboy0323
Aug 15, 2015 07:20 AM
beachrodder
Aug 7, 2015 04:27 PM
