water temperature switch questions
Old Jun 21, 2010 | 10:50 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Converting from a one-wire (idiot light) to a two-wire (guage) temperature sensor on my 1992 5.7 TBI engine. It's in my chevy truck but the wiring should be the same as F-body.
What does the second wire go to? Is it a ground?
Thanks in advanced
Old Jun 23, 2010 | 08:28 AM
Pocket's Avatar
Car: 91 Trans Am
Re: water temperature switch questions
It doesnt work that way
Cars and trucks still use the one wire sender for the gauge and the 2 wire CTS for the ECM/PCM
You need to plug them up correctly or neither will work and the engine will run rich/lean
Old Jun 23, 2010 | 05:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The sender unit for the idiot light is just a off/ on switch that turns on at low oil pressure and the one for a pressure gauge is a variable resistance that changes with oil pressure .
Both 1 wire so just install the correct type sender unit
Old Jun 23, 2010 | 07:51 PM
RyanEricW's Avatar
I think the OP wanted water temp, not oil pressure lol. I'm interested in this as well, not sure if my factory temp gauge is accurate.
Old Jun 24, 2010 | 01:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Fixed ;was in a hurry
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
