Speedometer wiring help.
Old Jun 24, 2010 | 11:33 AM
twquick's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.7L
I have a '92 Firebird Formula. The engine is a 350 from a Chevy truck and the trans is a 700R4 from an unknown donor. I bought it mostly apart. I've gotten it drivable and the speedo doesn't work. I went underneath and the VSS has no wires going to it. There are no connectors anywhere to be found under there. What I need to know is, where do these wires go after leaving the VSS? Do they come from the engine bay? From inside the car? From a virtual link to an alien spacecraft?
Old Jun 24, 2010 | 01:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speedometer Reads Zero? Just Keep It Floored!
Because it’s a 92 the setup should be:
The VSS goes to ECM pins B9 & B10.
Use B9 as the case side of the VSS.
The ECM output goes to pin 8 of the left dash connector.
That wire might be there, should be a
gray wire, you’ll find out after you wire the VSS.
Happy Racing!
Spin Me This Week … I’ll Spin You Next Week
LittleFranks
Sep 17, 2015 12:22 PM
Bull86
Aug 10, 2015 05:43 PM
marcusaw
Aug 10, 2015 08:13 AM
