Speedo problems
Old Jun 28, 2010 | 02:28 AM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Speedo problems
I swapped out my 110 mph cluster out for a 145mph cluster about 6 months ago and have had no problems with it till now or should i say this month. It may be the Texas heat but my speedo tach works perfect at night but during the daytime I noticed it either does not work at all or is flashing back and forth from zero to current mph. Is there a way to fix this?
During the day I would say it has a 30% chance of messing up on me but it is getting more often over the past month.
Old Jul 7, 2010 | 10:14 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Re: Speedo problems
OK it's gotten worse now it messes up a lot now.. I noticed my odometer doesn't work while the speedo is glitching up on me. Bad cluster or is it something else causing this?
Old Jul 7, 2010 | 11:50 PM
Magik Shaun's Avatar
Re: Speedo problems
Yeah, mine is stock, but it works randomly. Sometimes I think I know when it doesn't and does work (night and day) but then it just seemed when I was running late for work it wouldn't function. I'm not sure.. the Tach doesn't work either, or the Oil Pres. I don't know if it's the VSS or the cluster. It's electric, and I am a novice on that. Also, sometimes it seems that when I use my turn signals it causes the Speedo needle to fluctuate, then when I turn off my turn signal it is either fine again, or drops.
91 Camaro RS 305TBI.
Who can help us? It's aggravating.
Old Jul 8, 2010 | 08:36 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Re: Speedo problems
Mine is just the speedo thats messing up but I'm going to swap my 110 mph back in and see if it is the cluster or not.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
