Horn is inoperable after swapping sterring wheels
Old Jul 7, 2010 | 09:00 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
So I just took the original 85 TA wheel off and replaced it with one off an 88 GTA. The new wheel is the one with the radio controls built in(in the pic). Everything as far as the horn goes was installed correctly. Now do the yellow, orange or black wires for the actual controls need to have power as well?? I'm stumped. Thanks.
Old Jul 8, 2010 | 02:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Horn Blast Those Slo-Pokes Off Their Fons And Onto Their Loud Pedal !
On many thirdgens the wires going to the horn button are black.
However
black is also for radio control ground.
The
black wire from the car is sent to ground to sound the horn.
You can verify the horn button by connecting an ohmmeter between the
black wires from the wheel and watch the meter move to zero Ω when you press the button.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Jul 8, 2010 | 02:53 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: Horn is inoperable after swapping sterring wheels
From what I understand the turn signal cam is often responsible for this.
1984HO
Mar 19, 2021 11:59 AM
colton_carlson
Mar 8, 2019 12:21 PM
IroczFan
Oct 6, 2015 10:13 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
