TPS to ECM wires
Old Jun 29, 2010 | 03:16 PM
fluffyvt's Avatar
TPS to ECM wires
i have a 92 camaro with a 350tbi from a 92 c1500. i need to know which pins the ecm uses for the tps signal wires. i'm throwing a tps code and have replaced the tps and reset teh ecu. even got an adjustable one and moved it to 54-58. the code still won't go away. since i didn't do the swap i would like to make sure the pins are in the correct location at the ecm. btw if it helps its the round 3 wire connector. and the ecu is unknown. the serial number doesn't match for camaro so i'm assuming it's from the truck.thanks for the help
specialized
Jun 18, 2022 09:26 AM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
djmarch
Aug 19, 2015 12:07 PM
