How to disable check engine light?
Old Jul 6, 2010 | 11:46 AM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
Well my car is up for inspection now, but im not sure if it will pass inspection since it has a check engine light on. We took all the emissions off the engine so that is most likely why its on, but is there a way to disable the light or to take it out????
Old Jul 6, 2010 | 10:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: How to disable check engine light?
I'd think if they were going to fail for the light, then they'd be looking under the hood anyway, and thus fail you for not having the emissions equip in there long before they'd fail you for the light.
But you can simply unplug the bulb in the cluster.
Old Jul 6, 2010 | 10:17 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well i dont know the laws in PA or how strict they are but if they would fail you for a check engine light they will fail you for no check engine light. Removing the bulb is a common thing thats done to try and hide stuff like that and inspectors know that. Check engine lights go on briefly when the car is first started just to show they are alive and working. So if a tester is checking for a check engine light they will see the light did not turn on and will know the bulb is burnt out or removed which would be a failure. You would need to put it on some sort of timer or program the diagnostics out of the ECM.
Old Jul 7, 2010 | 10:23 PM
ranger77's Avatar
Car: 82 firebird
Srry forgot to add im doing the classic plate car, since i drive under 5000 miles on the car its exempt from the emissions test.
Old Jul 8, 2010 | 01:09 AM
polaris91's Avatar
Car: 88 camaro z28
im not sure how penn works but here in ny 95 and older you can have a check engine light and still pass
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
