where is my high beams
Old Jul 8, 2010 | 12:36 AM
n0mad's Avatar
Car: 92 camaro rs 25 aniversary
Transmission: auto
i got 2 sets of headlamps on the car and only have low beams. was told that the high beam switch is engaged by moving my wiper selector either towards me or away from me. it moves but does not engage the high beams or click or flash them. there's power to the switch because my wipers work. one of the 2 previous owners had my fan hardwired to come on automatically when the ignition switch is in the on position dont know if they are on the same circuit or not, any comments or suggestions or ideas would help
Old Jul 8, 2010 | 12:58 AM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: where is my high beams
There is a rod that travels from the lever down to a switch under the colum. I find the rod comes out easily (especially if the steering wheel has come off at some point... possible to fix the wobbly wheel problem we get). In any case, it's probably the problem. Just locating the rod... which you'll need to get under the dash with a flashlight. If you see the rod, and it's in the right place (you should be able to tell ,cause it would just be hanging there otherwise). if it is, then you need to open up the steering column, and find out if the rod is hooked into the lever to actually move the rod back and forth. I'm sure there's more to add, but I'll leave that to others to fill in! Good luck!
Old Jul 8, 2010 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check both the rod and switch at the base of the column.
JamesC
Old Jul 8, 2010 | 07:33 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
all of the above , a common enough problem . switch on column will slip down after 20 years of flipping beams . lowering steering shaft helps , loosen bolts/screws holding switch . slide switch up to remove slop , re-tighten screws . i have done this several times . its a PITA to get at but an easy/cheap fix . good luck .
Old Jul 8, 2010 | 07:43 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If your tilt column is loose it can also cause the lever and rod to not correctly engage the switch.
Old Jul 8, 2010 | 07:55 AM
Stephen's Avatar
Car: 87 GTA
As mentioned above, the floppy steering wheel is a common problem & cause of the high beam rod coming out of the switch. Be there myself just 2 years ago.
Does your steering wheel flop/"wiggle" when you move it, yet the column stays still? If not? I would bet that it did at one time, got fixed, but wen fixed whoever fixed it didn't get the high beam rod out back in place correctly before buttoning it all up & calling it done.
Steering Column fix
I think the above article should be replaced with this one......
Better article w/pics -- Steering Column fix
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
