Alternator problem
Old Jul 8, 2010 | 05:44 AM
mikael2's Avatar
Alternator problem
I have a 1989 iroc-z camaro that i bought with out a motor in it and when the guy pulled the 305 out of it he just cut wires and stuff and he gave me a 350 to put in it. I got most of the stuff hooked up but my alternator wont keep my battery charged and i dont know why i put a new alternator in it and a brand new battery. I have the wire goin from the battery to the alternator and i thought i had the plug right but i dont know if it is the right one does anyone know where the wires come from that go to the alternator and also i am having some trouble with the vacuum lines if someone has a diagram for the routing that would be great. Thanks.
Old Jul 8, 2010 | 11:56 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alternative Information
The heavier red wire goes to the positive stud, and should have power at all times.
The thinner
red wire goes to terminal S (the sensing circuit) and should have power at all times.
The
brown wire goes to terminal T (the turn-on input) and should have power when the key is in the RUN position.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Jul 9, 2010 | 07:06 PM
mikael2's Avatar
Re: Alternative Information
thank you i found the wires but now the alternator is making a wining sound when i start it but when i take the plug off it quits does anyone know what could be the cause? Maybe a bad alternator? I dont know and i also need to know where the vacuum lines go on my carb its a quadrajet 4bbl carb and i need to know where they go on the carb and to where in the engine bay. and also what vacuum lines go to the intake manifold and where they come from its a edlebrock preformer intake. Can anyone help me out.
Old Jul 12, 2010 | 12:55 PM
NINÅ's Avatar
Transmission: 765R4
Refreshing Alternator Wine Cooler
It sounds like one of the diodes went bad.
You can open it up to locate and replace it, or to save time just install a new alternator.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jul 13, 2010 | 04:22 AM
mikael2's Avatar
Re: Refreshing Alternator Wine Cooler
ok thanks i got that figured out now i just have to figure out all of these vacuum lines. Thanks for the help NINA
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
