No Power Anywhere?
Old Jul 8, 2010 | 06:09 PM
lackid20's Avatar
Car: 1985 Z28
Engine: 5.7L TPI
No Power Anywhere?
So I was trying to start my Iroc the other day... it has some problems. It was cranking over and the battery was almost dead, then I heard a click and I lost power everywhere. No headlights, no interior light, nothing. I charged the battery and still nothing. I assume its a fuse of some sort but I'm not exactly sure where it is located... any advice would be helpful. Thanks.
Old Jul 9, 2010 | 12:39 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No Power Anywhere?
Fusebox under driver side dash. Also there's fusible links in the engine bay.
Old Jul 9, 2010 | 01:46 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Check the positive cable connection at the starter. If its on the terminal but the nut isnt tightened down it can short. Will kill power to everything if it is not hooked up properly.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
