Fuel Gauge Problems
Old Jul 10, 2010 | 09:26 AM
shelad's Avatar
Car: 86 Camaro
Transmission: th350 w/2500 stall
Fuel Gauge Problems
Heres my problem. When I turn my key on, my fuel gauge shows a pretty accurate reading. But when I turn my lights on, it usually slams to below empty. If I turn my dimmer down, as it turns the dash lights out, the gauge returns to where it was. It doesn't appear that anything else affects it. Just the dash lights. I see that the ground circut for the gauge and the dash lights are run together. Could this be a ground problem and should I try grounding the wire coming from cluster? Thanks Larry
Old Jul 12, 2010 | 07:42 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Fuel Gauge Problems
sounds like you're on the right track. some of these ground connection get corroded and rusty over the years.
Old Jul 13, 2010 | 09:03 AM
shelad's Avatar
Car: 86 Camaro
Thanks 1ADan. I imagine that the ground for this was probably mixed in with the harnesses for the computer. That's all gone. Even my gauges do not work. There are no connectors for the sending units. I installed after market gauges instead. I'm going to try grounding it later today. Thanks again, Larry
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
