Seen this before, turn to start gauge fuse pops
Old Jul 12, 2010 | 09:45 PM
oil pan 4's Avatar
Car: 89 Firebird
I have a new problem with my car.
The gauges quit working a few days ago. When I put in a new fuse I can turn the key to on and every thing works but when I go to start the gauge fuse pops.
Has any one seen this before?
Also I had to pull the dash apart to fix some burned up wires, all the heavly damaged ones were pink with a stripe which means they should have been for the gauges.
Old Jul 13, 2010 | 03:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
One of the gages is shorted or one of the wires going to it.
You can determine if the problem is inside or outside of the dash by disconnecting the dash connectors.
If the fuse still blows, the problem is inside.
Then you’ll can internally disconnect the gages one at a time until the problem goes away.
Happy Racing!
How Come I Drive 400 Miles Most Weekends And Windup Where I Started?
Old Sep 18, 2010 | 02:43 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Re: Gage Rage
Where exactly are the dash connectors at under the dash? I'm having this same exact problem. One day I'm driving along, I hit the gas and boom I blow the gauge fuse. Now every time I start the car, it will blow that same fuse immediately.
Old Sep 20, 2010 | 09:55 AM
NINÅ's Avatar
Transmission: 765R4
Gage Rage
They are located near the bottom of the dash, one on each side, in back of it.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Sep 24, 2010 | 01:13 AM
camarocam's Avatar
Re: Gage Rage
Same problem here, too. I have a 1990 iroc z and when i floored it, the fuse popped and guages went out. Same exact problem. Any ideas?
Old Sep 24, 2010 | 02:10 AM
Drew's Avatar
Re: Seen this before, turn to start gauge fuse pops
-deleted
Old Oct 9, 2010 | 11:48 PM
firebird123's Avatar
Car: 1991 firebird
Engine: 3.1 v6
Transmission: ?
Axle/Gears: ?
I have the same problem but every time i put in a new fuse it work for a couple of day or pop after i hit the gas.
Old Oct 10, 2010 | 12:16 AM
camarocam's Avatar
For me, It turned out to be a connector located underneath distributor cap. Apparently the wire/connector got fryed sitting on the manifold or something to that degree(that's what the tech told me) Anyway, I went to the junkyard and pulled a connector off an old transam. Guages are all working again and no more fuese poping. Hope this helps.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
