'89 Firebird -- A few electrical problems.
Old Jul 14, 2010 | 08:26 PM
89Firebin's Avatar
Car: 89 Firebird Formula 350
Engine: 1974 350
Transmission: '84 Trans Am T5
Axle/Gears: Borg warner 3.27
Hi,
I have a few electrical problems on my 89 Formula. First of all, I swapped to carb from TPI and the cruise doesn't work, I dont know if it worked before the swap (car couldnt propel itself). I check the grey wire at the brake pedal and it has 12 volts with the key on and the cruise switch on. There is also vacum at the servo under the hood. Where is the cruise control module located and Where should I even start?
Second is a short in the blinker/back up light circuit. All of the lights work flawlesly (blinkers blink like they should, back up lights work) But after a little bit it blows the fuse. I looked a little but didnt find anything. What/where do I look for this also???
Thanks.
-Ryan
Old Jul 14, 2010 | 10:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: '89 Firebird -- A few electrical problems.
This is for a 1992 - but should be the same:
Wiring diag for CC: http://www.austinthirdgen.org/mkport...se_control.jpg
Tons of wiring diags here: http://www.austinthirdgen.org/index.php?pid=19
Maybe that will help some.
Old Jul 15, 2010 | 06:27 PM
89Firebin's Avatar
Engine: 1974 350
Yeah thanks, that will help some, but does anyone know where the module is located and how to diagnose the system??
Thanks.
Old Jul 15, 2010 | 06:42 PM
Car: 1992 RS
Engine: Carbed 350
The cruise control module is located pass side, up in and behind the ECM.
Old Jul 17, 2010 | 10:45 PM
89Firebin's Avatar
Engine: 1974 350
Thanks, I found it and got the cruise to work. It was broken wires on the blinker lever. So now any ideas on the short?? Is this a common thing?
BRoss99
Aug 10, 2025 05:08 PM
toones
Jan 6, 2016 06:00 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
