Battery Drain Dilemma
Old Jul 17, 2010 | 03:44 PM
tr6guy's Avatar
Car: '72 Triumph TR6, '85 Camaro
Engine: 2.8 V6
I need some help here. Got an 85 Berlinetta 2.8 with a slow battery drain. NINA - I followed your directions found on other similar posts. Put an ammeter in series across the neg terminal - with everything off, doors closed, etc something is drawing about an amp of current. I pulled every fuse from the fuse block but no drop in current. What am I missing? Where to look next. By the way - had the alternator checked, I have an open diode, but even with the alternator disconnected, I'm still drawing. Any thoughts out there?
Old Jul 17, 2010 | 05:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Battery Drain Dilemma
Put ear against hump in trunk and listen to see if the fuel pump is running with key out. I know on the V8 cars, the oil pressure sending unit can go bad and make the fuel pump run always regardless of the key.
Old Jul 17, 2010 | 06:16 PM
tr6guy's Avatar
Engine: 2.8 V6
Thanks. I've got to put this project off 'til tomorrow am. I don't hear anything from the front, but will look into your idea. Thanks again.
Old Jul 18, 2010 | 09:31 AM
tr6guy's Avatar
Engine: 2.8 V6
Ok. I figured it out. While listening for a run on fuel pump, I noticed the trunk light was on - hadn't noticed it before. Went back to square one, determined that the accy fuse was the draw source, turned OFF the trunk light that had somehow been turned ON. Problem solved. I'm almost too embarrassed to admit how simple it was, but I guess the simple solution is usually the right one.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
