Elimanating wire's & ECM
Old Jul 17, 2010 | 10:27 AM
Kaycee's Avatar
OK fellas 86 Z-28 carbed 305 fixing to pull the 305 and replace with a 350 and want to eliminate all the crap of smog and millon's of relays.The ecm has me baffled can I elimanate all this crap and throw a NON computer Hei in and go or do I need the ecm to run some other stuff fans ,lights,etc
Thanks for the info and I usually try to search first but I can only read so much A.D.D. jk
Old Jul 17, 2010 | 11:51 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Elimanating wire's & ECM
Computer controls the carb as well, so you'll have to get a different carb unless there's a way to tune a cc-Quad without the computer.
I don't think ECM controls the fan. Either way, I recommend a seperate fan controller to everyone - they are great! No more fan switch in the head to go bad, fully adjustable, and runs any electric fan. I have a Flex-a-lite, there are others as well.
If auto, you'll need a way to lock the torque converter.
I'm no expert on the carb wiring, but most if not all of the wiring in the pass side harness can go - but I always tell folks to keep it and just tuck it all in the fenderwell - it can be totally hidden there, that way it's available if something is needed. And later you have an abundance of in-cabin to engine bay wires to make use of for external lighting, fan switches, fog lights, whatever. I'm always using wires from my old harness for things.
Old Jul 17, 2010 | 12:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you go to a non-CC carb, find a way to lock up your TC if you've got an auto, and switch to a vacuum advance distributor, figure out how to wire up the in-tank fuel pump (if you've got one), the entire passenger side harness can go.
Old Jul 18, 2010 | 09:57 AM
Kaycee's Avatar
Thanks for the replys,Pretty much got everything I need from other projects I have collected over time.I think I'll do the same to all the emission crap,no emmision problem here in WY.
Old Sep 15, 2010 | 12:11 AM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
how would you lock up the TC?
Old Sep 15, 2010 | 06:13 PM
Car: 1992 RS
Engine: Carbed 350
Read this: https://www.thirdgen.org/forums/carb...c-control.html
Do those tests to see which switch you have in the tranny (normally open or normally closed). If you have the right one, the thread tells you how to wire it. If you have the wrong one, you'll have to open the tranny pan and replace it.
There's several kits available to do it, I'm running the TCI kit - it works, but the small vacuum switch they supply is junk, and it easily breaks - I just use a manual switch and turn it on/off myself. It's worked fine that way for 4 years now.
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
