Under hood light
Old Jul 19, 2010 | 01:57 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Under hood light
I have a 1987 camaro RS with a light under the hood. This light , I am guessing is supposed to come on when you open the hood. does any body know what turn's the light on and off ? There is only one wire to it and that is a ground wire, It seems to have a vacuum line to it ? I cant find anything on the elec schematics or vacuum diagrams.
Old Jul 19, 2010 | 02:44 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Under hood light
It should definitely be in the wiring diagram, I believe in the interior lighting section.
Old Jul 19, 2010 | 02:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by rkg8554
I have a 1987 camaro RS with a light under the hood. This light , I am guessing is supposed to come on when you open the hood. does any body know what turn's the light on and off?
Mercury switch. You should have one wire with a connector along with a ground wire.
JamesC
Old Jul 19, 2010 | 03:36 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
That make's sense. But is there any reason for a vacuum line to be hooked to it. Maybe thats why it has never worked. I have a chiltons for the camaro, but none of their schematics show the under hood light. Is there some other schematics I should get.
Old Jul 19, 2010 | 03:47 PM
JamesC's Avatar
I have no idea why a vac line would be in place in that position. If the wire with the connector was there, you could, of course, check it for power. Mine's covered with a loom, so perhap the wire in question is buried in there somewhere.
A shop manual will have the diagram.
JamesC
Old Jul 19, 2010 | 06:53 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's supossed to just have one wire to it, and that should be a power wire, not a ground.
Old Jul 19, 2010 | 07:49 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Well I guess somebody used the light fixture for a plug for the vacuum line, be it that it was run inside the wire loom from the harness to the light. There is no wire in the loom to the light from the harness other than a ground wire that grounds the hood light fixture to the engine compartment. Guess I'll get a shop manual so that I can possibly find the correct wire. Thanks alot guy's.
Ron
Old Jul 19, 2010 | 08:25 PM
Car: 1992 RS
Engine: Carbed 350
If I remember correctly, the hood wire on mine was red or orange. Can't tell you exactly where it came out, but was in the pass side really close to the strut tower. The light housing shouldn't need a ground, it should ground itself since it's bolted to the hood. Hood is grounded being that it's bolted to the body.
I actually removed my underhood light, and used the wire from it, connected to a switch, and installed 2 14in LED strip lights under the edge of the front of the hood, just behind the hood latch. They point towards the bay, light reflects off the hood the entire way down, so the light is always from above. They work really well, veryt very bright, yet not in your eyes, and lights up the entire bay really well - I can actually work under the hood at night with these things and no other light.
Old Jul 19, 2010 | 09:12 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Thanks so much!!! The led light bars sound like a great idea!!! Thanks again
Old Jul 19, 2010 | 09:25 PM
JamesC's Avatar
I double-checked my 85. There are two wires as I mention above. The ground wire, according to the shop manual, is a 'strap, hood to body.' Perhaps the set-up is different in other years.
JamesC
Old Jul 19, 2010 | 10:31 PM
Car: 1992 RS
Engine: Carbed 350
Oh - might be extra ground straps in some years - mine doesn't have one.
This is like the LED strips I got:http://www.autozone.com/autozone/acc...ier=60068_0_0_
They are flexible SMD leds with sticky tape on the back, and I placed so they faced down the hood, shining away from you, on a little edge that is just behind the hood closure.
Old Jul 20, 2010 | 01:13 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
IN this thread there are a few photos of the wiring for the underhood light in an 82 Cross Fire car.
https://www.thirdgen.org/forums/elec...-disaster.html
Power for the light is picked up from a tap into the blower motor high speed power wire (red wire in the background of the last photo). The power source can be any always hot point in the engine compartment. This way the light will come on if the engine is off. The circuit usually has an in line fuse to protect the wire form the tap point to the light. My 82 car has the fiberglass hood, so the harness has two wires in it. Both are black. The power wire runs through the connector. The ground wire connects to the light base and can be seen looping below the connector in the photo.
The ground wire connects to the metal body at a ground point by the hood hinge. You can also see the copper braid ground wire the connects to the metal backing on the under hood insulation. It connects to the same ground point as the light ground does.
In the end, the lamp needs two wires to work. A power wire and a ground wire. At the lamp, the ground wire should be connected to the metal lamp base. It may or may not be jumpered to the metal hood at that point or run down the harness to another ground point.The power wire to the lamp socket.
Old Jul 20, 2010 | 08:21 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Again thank you all!!!!! This site is fantastic with a bunch of great guy's. Your suggestions really help, along with the pics. I went to EBAY last nite and got me a service manual ( oem ) THANKS AGAIN
Ron G
Old Jul 20, 2010 | 10:05 AM
Car: 1992 RS
Engine: Carbed 350
Oh - forgot about the fiberglass hoods Those would need a ground wire for the light!
Old Jul 20, 2010 | 10:23 AM
JamesC's Avatar
My 85 has a steel hood with the body ground, which is located just below and behind the pass side hood hinge.
JamesC
Old Sep 3, 2010 | 02:38 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Hey James, I have a 85 w/ a glass hood. Can you take a couple of pics of the hood light and the wiring route. My original light was destroyed by fire and I would like to get my new one mounted and routed as close to original as possible. Thanks! (I've read lots of your posts since I became a member. Great information from you!!!)
Old Sep 3, 2010 | 01:25 PM
JamesC's Avatar
Here's the general routing.
1st pic. Gray connector. Follow the loom six inches or so and you can see the in-line fuse.
2nd pic. Over the blower motor and up the hinge.
3rd pic. Note the ground from the aforementioned loom.
JamesC
Attached Thumbnails Under hood light-img_0092.jpg   Under hood light-img_0096.jpg   Under hood light-img_0101.jpg
Old Sep 3, 2010 | 01:27 PM
JamesC's Avatar
And across the hood. Note the connector and ground wire. Since the light was interfering with my STB, I removed it.
JamesC
Old Sep 3, 2010 | 11:32 PM
85 ZXX's Avatar
Thanks James, I assume the light works by turning on the dome light or opening the door?
Old Sep 4, 2010 | 06:43 AM
JamesC's Avatar
By opening the hood (mercury switch).
JamesC
Old Sep 4, 2010 | 11:59 PM
85 ZXX's Avatar
Can you show a pic of the mercury switch? Is it built into the light housing? I have a TPI Harness.
Old Sep 5, 2010 | 06:59 AM
JamesC's Avatar
I believe it's in the light housing itself.
JamesC
Old Sep 5, 2010 | 06:47 PM
85 ZXX's Avatar
Yep, I believe it is, I hooked it up to the battery and tilted it and it came on then tilted it horizontally and it went off.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
