Washer fluid motor
Old Jul 20, 2010 | 02:20 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Washer fluid motor
I have a 87 RS that had a non tilt column in it. My old column was equiped with delay wipers and cruise. I got a used tilt column and installed it , it is also equiped with delay wipers and cruise. My winshield washer pump is mounted to the wiper motor assembly. Is it normal for the washer fluid pump to work only when the wipers are on? I thought that you could turn on the washer fluid and that would also turn on the wipers to clear the fluid from the windshield and then after a few strokes the wipers would shut off.
Old Jul 21, 2010 | 01:55 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wishin’ 4 A Washin’
Both those sentences are correct.
The wipers can be OFF and you just have to rotate the thumb wing a little and the washer and wipers will come on for a few seconds.
Also, the wipers can be ON and you can still request washer fluid with the thumb wing.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Jul 21, 2010 | 03:14 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Re: Wishin’ 4 A Washin’
OK I guess I have a problem, my washer fluid pump will only work when the wipers are on. This works with the thumb wing as you call it. If I try to use the washer fluid with the wipers off it does not work. Do you think this would be a problem with the switch in the column or in the wiper motor assembly itself? Thanks for the help!!
Old Jul 22, 2010 | 01:29 PM
NINÅ's Avatar
Transmission: 765R4
Wishin’ 4 A Washin’
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the gray wire coming out of the steering column from the washer/wiper controls.
Or you can probe the
gray wire at the under-hood assembly.
When you press the thumb wing are you getting 12 volts?
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Old Jul 22, 2010 | 02:23 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Will do as soon as I can. Will let you know what I find out. Thanks alot
LittleFranks
Sep 17, 2015 12:22 PM
Randomtask2
Aug 26, 2015 03:34 PM
fonzie85
Aug 13, 2015 11:50 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
