Adding VATS to Vehicle
Old Jul 21, 2010 | 12:33 AM
92K2500's Avatar
Car: 1992 Chevy K2500
Engine: TBI 413 SBC
Transmission: NV4500 5 Speed Manual
Axle/Gears: 14 Bolt Semi-Float 3:73 TrueTrac
Hi I have a 92 Chevy Truck with a MAF Swap in it...the 7427 PCM and am wondering if it possible to swap in a VATS setup into it. I am not afraid to work, I am looking for the unique idea here. I would like to do it but am also willing to accept that it can't be done if that is how it is.
Thanks for your help in advance.
Old Jul 21, 2010 | 12:39 AM
19Camaro89's Avatar
Car: RS Camaro
Engine: 355 cu. in.
Transmission: TH700R4
Axle/Gears: 10 Bolt 3.23
Re: Adding VATS to Vehicle
not sure if that ecu can be adapted for vats but make yourself a kill switch?
Old Jul 21, 2010 | 12:45 AM
Stephen's Avatar
Car: 87 GTA
You'd need the VATS module & a key cylinder that has the connections inside it, to actually read the key.
Interesting idea. Most people take VATS out, not put it in.
Old Jul 21, 2010 | 01:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Most folks are removing and not adding
It would be much easier to rig a hidden switch - could splice into a million places, cutting power until it was flipped.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
