V-6 to V-8 motor swap
Old Jul 26, 2010 | 05:17 PM
Perfomer's Avatar
I am putting a 406 in a 92 RS that had a v-6 . I have a donor 89 camaro will the under hood wiring (V-8) connect to the 92 V-6 fuse box ? I am going to use a Carb just need the starter ,alt ,a/c fans and dist. wires . I am also going to try and run long tube headers any suggestions ?
Old Jul 26, 2010 | 05:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: V-6 to V-8 motor swap
The V6 wiring would be fine, why try and swap out - all you need is standard stuff. All the pass side wiring will not be used, all of the driver side wiring will (driver side wiring is the basics like alt, tach, lights, etc.). What are you using for a tranny?
Old Jul 26, 2010 | 10:25 PM
Perfomer's Avatar
When you talk about passenger side and driver side wiring were are you talking about ? I am using a 700 r4 I have a friend that builds Transmissions for my race cars we are going with a 4000 stall convertor I know that the lock will not work .
Old Jul 26, 2010 | 10:47 PM
Car: 1992 RS
Engine: Carbed 350
pass side wiring harness, and driver side wiring harness. pass side is all computer functions that you'll no longer need - it runs under the pass footwell. driver side harness is all basic functions, and the same whether V6 car or V8 car - no need to replace any harness - it runs through drivers side footwell.
Old Jul 26, 2010 | 11:02 PM
Perfomer's Avatar
Thanks , the harness on the 92 was cut up by the previous owner , the 89 is complete just wondering if the 89 harness will plug into the 92 connection block on the drivers side and work ?
Old Jul 26, 2010 | 11:39 PM
Car: 1992 RS
Engine: Carbed 350
OK - I see! I thought that you thought that you needed a V8 engine harness because you were putting a V8 into a V6 car. I have no idea if the bulkhead connectors will match up. I do know there's a bolt hidden in the middle of the connector on the engine side of the firewall that you'll have to remove before the engine harness will come off the firewall connector.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
