Help with 1986 Trans Am
Old Aug 5, 2010 | 10:41 PM
beachbummer's Avatar
I have an 86 Trans Am. The engine is a 305 and has had a lot of work. The problem is that After I seated the rings and was driving the car back home it lost all Electrical power the car just faded away. The dash lights got dim and the engine lost power. The headlights never went out nor got dim. I have replaced the switch, and I am getting power to the switch, but cant get power to go any further. The electric fan was wired up to a toggle switch, and hte wires were running through the main wiring harness, and while driving they shorted out. I have taken the wiring harness apart and can find no broken wires! HELP I need this thing running again , so it can be finished!
Old Aug 6, 2010 | 05:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Help with 1986 Trans Am
check the fusable links by the starter
Old Aug 9, 2010 | 11:47 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power This Hour
OK if the headlights never went out you might be talking about the ignition switch.
If you’re getting power to the switch but not out of the switch, there is a bad connection at the connector point, or the main movable contact went bad.
If it’s the latter replace the switch.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Pilotrick50
Sep 2, 2015 12:48 PM
michealleger
Aug 26, 2015 03:29 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
