Rear Hatch Wiring
Old Aug 7, 2010 | 12:14 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Rear Hatch Wiring
I had to remove my rotten wrap around spoiler last summer and when it was done, the electrical connections that ran up to the third brake light were taken out as well. Without these I have no rear defrosters. Here is what I have left, I can figure out what to do except I don't know what the wire hooks to because all I have left in the hole where they look like they would plug into is these little metal ends.
Attached Thumbnails Rear Hatch Wiring-rearhatchconnect.jpg   Rear Hatch Wiring-rearhatch.jpg   Rear Hatch Wiring-rearhatch-wiring.jpg
Old Aug 9, 2010 | 12:15 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Rear Hatch Wiring
The spring loaded connector that contacts with the pad on the hatch just powers the HMSL (high-mount stop light). The power to the hatch defroster should attach to a connector welded to the upper and lower locations on the hatch struts.
Lon
Old Aug 9, 2010 | 12:40 AM
Mr Froman's Avatar
So it could be a bad relay? I can hear it click behind my suspension badge with I try to use them.
Old Sep 13, 2010 | 12:34 PM
Mr Froman's Avatar
What if I want to put in a third brake light? I noticed the high mount ones have specific defroster wire patterns and because I had a wrap around spoiler I don't.
Old Sep 13, 2010 | 01:02 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Wire it off of the brake light switch.
Old Sep 13, 2010 | 04:35 PM
Drew's Avatar
The later cars just have the defroster go around the third brake light. The wiring for the 3rd light comes up the roof and there's a curly Q wire from the roof under the headliner to the light on the bottom of the hatch. Short of changing the entire hatch, it'd be hard to adapt since the mount is a permanent part of the hatch. You'd be further ahead to get a spoiler with the 3rd brake light and use the stock wiring you removed to hook it up.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
