Left the ignition on and check engine light doesn't come on before start
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I left the ignition on over night by mmm mistake, and now the check engine light doesn't come on. I think I burned out the bulbs, but I wanna know if anything else besides me could be the blame. The fuse is ok also..
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash Needs A Check Light For Check Engine Light - Light
With the ignition OFF disconnect the ECM.
Using a fused jumper (1 amp is good) ground pin A5 of the connector (not the ECM).
Now, turn the key to the RUN position.
Does the Service Engine Soon light come on now?
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Happy Racing!
Re: Dash Needs A Check Light For Check Engine Light - Light
Well, I am not sure or more like I don't have a clue where the ECM is, or pin A5 is. If there is a way to tell me, please let me know.
Transmission: 765R4
The ECM located above the “passenger” footwell.
Happy Racing!
Happy Racing!
The check engine light mysteriously started working again... hmmm
