Buzzer comes on when headlights are on/ no gauges working
Old Aug 11, 2010 | 09:05 PM
DirtyCanadian's Avatar
There is a loud annoying buzzer noise that comes on when i turn on my headlights, also not one gauge on my dash works???? i got it back from the paint shop like that and they said they checked the fuses apparently not the problem. can anyone tell me where I can start or has had any experience with this? it is an 83 trans am.
Old Aug 12, 2010 | 03:16 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Spilled Paint On Electrons
You must check the fuse yourself.
If the
GAGES fuse looks good
use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe both sides of the GAGES fuse.
Is there power both sides?
Happy Racing!
Make Noise, Turn Left, Repeat
Old Aug 27, 2010 | 11:51 PM
Re: Buzzer comes on when headlights are on/ no gauges working
3 fuses were out. They must not have checked them as it is not easy to get at if your not a small guy, i had to pretty much fold the seat back and lay upside down on my back in the seat to check it without turning my neck 280 degrees.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
