How to connect battery to car with engine removed?
Old Aug 28, 2010 | 02:21 AM
vyper883's Avatar
Hey fellas
Has anyone encountered this before? I have an 86 IROC roller. Removed engine about 9 -10 yrs ago. Hooking up a battery of course yields nothing as there is no power to main harness. Does anyone have a quick and dirty method to hooking up power to the car's electrical system? I need to roll up my windows to wash the car. I'm going to start restoring it soon and the body needs to be clean. Thanks in advance.
Old Aug 28, 2010 | 02:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to connect battery to car with engine removed?
Plug a jumper into the alternator connector? Plug a jumper into the fuse box under the dash? Unplug the window switch and jump the contacts on the socket?
Old Aug 28, 2010 | 02:49 AM
Twin_Turbo's Avatar
you need to connect the heavy gauge wires that run to the starter to get power to the main harness if you connect the battery in the stock location. Watch out for loose wires that could cause a short
Old Aug 28, 2010 | 03:08 AM
vyper883's Avatar
Thank you Sir!
BRoss99
Aug 10, 2025 05:08 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
