No spark at coil
Car: Red '89 GTA
Engine: TPI LB9
No spark at coil
I have an '89 GTA with the lb9 305 TPI engine and manual transmission.
I have already replaced these parts: sparkcoil, spark control module, dist cap, rotor, sparkcables and plugs.
The starter turns but there is no spark at the coil. The computer gives no problem codes. What could still be the cause of the fact that it gets no spark at coil?
Any help is appreciated, thanks.
Car: Red '89 GTA
Engine: TPI LB9
Re: No spark at coil
Yes it runs and there's definately gas coming to the engine. So that's not it.
What else could it be?
If it were pass key problems it wouldn't turn at all, right? And what about flywheel sensor, does the car run badly when that one is gone or doesn't it start up at all? Are there any relays that could be the problem?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There is no flywheel sensor. If the fuel pump is running for 2 seconds after you stop cranking, then the pickup coil is good. Do you have voltage at the coil primary?
Car: Red '89 GTA
Engine: TPI LB9
Well if there is no flywheel sensor that is eliminated as a problem.
I can't hear the pump running after cranking. It definitely runs when I turn the key to just the power position, although not every time. Is it supposed to run two seconds after every cranking?
Where is the pickup coil exactly? Can anyone show a pic or give a link to a pic where this coil is or what it looks like or both? And what is the coil primary? English isn't my native language so I don't know the correct terms.
But we have tried hooking the sparkcoil directly to a sparkplug with a cable and it gave no spark during cranking.
I noticed a cable connector is a bit fried just near the distributor. Can anyone identify what this connector is? And if this could be the problem? I have attatched a pic of this.
Thanks for your help!
Engine: 383 Carb
Transmission: 4L60
Yes, the fuel pump needs to run for 2 seconds after every cranking. The pickup coil is inside the distributor under the ignition module.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Since you have no spark at the spark plugs when cranking,..... work your way back into the car ( all the way to the fusebox . ignition switch if you have to ! ) until you find power again.
Nothing at plugs? Then check the coil wire-to-cap connection.
Nothing at coild wire-to-cap? Check Coil-to-coil wire connection.
Nothing there, Now check the Pink wire leading from coil to distributor ( Key ON !)
Nothing there, Check the pink wire from the harness to the coil. ( Key ON ! )
You want to be sure that the Pink wire from the harness to the coil ( and from the coil to the distributor ) is showing 12 volts when the key is in the RUN position. If there isn't 12 volts on the BATery circuit than you can change every piece under the hood and still not have spark !
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Foiled By The Coil
The ignition coil consists of two coils of wire, one being the input or primary, and one being the output or secondary.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Car: Red '89 GTA
Engine: TPI LB9
Re: Foiled By The Coil
Okay thanks for the help. There seems to be current coming to the spark coil. But apparently not out. Is that possible?
Since the fuel pump does not run 2 seconds after cranking I'm assuming it could be the pickup coil and am proceeding to buy one and get the old one replaced.
What are usually the "symptoms" of a bad pickup coil?
And does anyone know what connector it is in the pic I attached above?
If you have voltage to the remote coil and no voltage from it - then replace the coil FIRST. (I'd recomend any aftermarket performance coil ) You need spark to the cap before looking for any other problems to fix !
IIRC there is a fuel pump cut-off on the oil pressure switch..... no oil pressure - no fuel pump. If your not making spark the car will not fire or produce any oil pressure. The oil pressure switch might not be allowing voltage to the fuel pump as a result.
Just start with replacing the remote coil and try to fire it up ! If it doens't star THEN start dealing with other possible issues.
Engine: 383 Carb
Transmission: 4L60
He's already tried replacing the coil.
If there's 12 volts coming into the coil from the harness and no voltage going out to the distributor,.......... What DOES that mean ?? I just installed a brand new - from the box - distributor that was dead 2 weeks ago. Even new parts can be defective and his replacement might not have even been new.
IIRC the fuel pump relay only energizes the pump for a few seconds when the key is turned to "RUN". ( builds pressure in the fuel system.) It's not a constant power source for the pump - corerrct ?? Once the Key is turned to START and the engine cranks, oil pressure builds and the fuel pump cut-off switch "switches" sending 12 volt power thru Tan/White wire to the MAF, FP relay and fuel pump.
The relay and the switch are 'hot' at all times. Since the relay only energizes the pump itself for a couple seconds something else needs to supply power to the pump. No oil pressure - no fuel pump. Disconnect your oil pressure switch on a TBI, TPI, or MPFI and try to start the car. I'll bet the pump will only run for a few seconds and then quit. It's not a Bypass........ It's a safety so that the fuel pump will not run if the engine isn't building oil pressure.
The starter turns but there is no spark at the coil .................. There seems to be current coming to the spark coil. But apparently not out.
Engine: 383 Carb
Transmission: 4L60
Car: Red '89 GTA
Engine: TPI LB9
I'm trying to find a pickup coil on the internet but no sellers seem to ship to Finland. I usually find parts on ebay but can't find this one. I've been searching for "firebird pickup coil" but there are very few results for an actual pickup coil and those are for v6, and most results are just the regular ignition coil. What part number should I be looking for if it can't be found under Firebird?
Being in Finland will make getting parts more difficult for you. If you find a "pick up coil" seller on E-Bay Than check to see if he is just a seller - or a parts supplier. If It's just a guy selling his stuff you might be out of luck - but if it's a supplier than contact them and request correct the part directly. A supplier might have what you need and should be willing to ship international once you make contact.
P.S.
Very cool,... I had always believed that the relay only ran the pump for a couple seconds with the turn of the key - then it quit ( timer ) and turned over control of the pump to the switch..... I learned something new ! My whole understanding of what that switch is for was wrong ! The only time I had to deal with one I installed a 2 pin from an 88 into a 91 that needed a 3 pin; The pump was good but had no oil pressure readings.
P.S.
The fuel pump will run perfectly happily all day long without the oil pressure switch even installed,
Transmission: 765R4
I Find It Easy To Cross The Finish Line
Here’s a good finish to the story.
Woodys-Auto-Supply.com
They ship to Finland.
Happy Racing!
Engines Run Best Right Before They Blow Up
Happy Racing!
Car: Red '89 GTA
Engine: TPI LB9
Re: I Find It Easy To Cross The Finish Line
Hmmmm.... cant find a pickup coil for my car on that address. Does it come under other names as well? If so what? Thanks guys for the help!!
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Here you go STD-LX342 is the part# from there site . Your Welcome in advance .
Car: Red '89 GTA
Engine: TPI LB9
Yes thanks for the help with the pickup number!
If I would like to get a new ECM while I'm at it, what should I be looking for? This is the number on it:16198445. Will searching for this suffice or do I need other details as well to get the correct ecm? Since I'm the third owner of the car there is no way for me of being sure this ecm is the original or correct model. And should I get one that is brand new (if they are made still) or used? Thanks!
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
