Not F-body but GM electronic glitch
Old Aug 13, 2010 | 05:35 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Having a strange problem with my work van, a '99 Chevy express van 2500 with a 5.0.
the speedo is reading two or three times the actual speed. At approx. 40 the needle is buried and the engine shuts down untill the speed drops a little. Tried a new cluster and the same thing happens. The trans wants to shift into over-drive way too early and lugs the motor. Driving in 3rd helps but cant get over 35 or 40 before the engine shuts down. Has anyone else had a problem like this? I've been pulling my hair out to no avail, and I don't have any to spare. Any ideas are welcome. Is there a way to check the speed sensor in the tranny?
Old Aug 13, 2010 | 06:59 PM
HankL69's Avatar
Engine: 5.0 / 350
Re: Not F-body but GM electronic glitch
bump
Old Aug 13, 2010 | 07:26 PM
HankL69's Avatar
Engine: 5.0 / 350
Not the speed sensor. Put a new one in and no differance. I'm thinking it must be the computer. Any body have any thoughts on this.
Old Aug 13, 2010 | 08:39 PM
HankL69's Avatar
Engine: 5.0 / 350
bump
Old Aug 13, 2010 | 08:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The ECM's have speed limiter's programmed in on the chips. Sounds like the VSS is translating speedo gear information incorrectly, and thus feeding the speedo and the ECM false speed readings, making the ECM shut down fuel output when that magic number is reached.
Have you tried checking/replacing the speed housing on the tranny or the VSS unit?
Old Aug 13, 2010 | 09:04 PM
HankL69's Avatar
Engine: 5.0 / 350
I replaced the VSS on the transmission with a new one from NAPA. No change!
I realize that the engine is shutting down because the computer thinks the speed is too high, I just don't know why,
Old Aug 13, 2010 | 10:11 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Not sure if this applies but on older cars they have a buffer box that conditions the output of the speed sensor for the ECM. Possibly your problem
Old Aug 14, 2010 | 06:52 AM
HankL69's Avatar
Engine: 5.0 / 350
Where in the system would I find the buffer box and is there a way to check it.
Old Aug 14, 2010 | 09:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its the inst cluster. There is a recall on those.
Go 2 dealer and ask if your van is on the recall list.
If its over so many miles or time they wont fix it 4 free tho.
Old Aug 14, 2010 | 07:39 PM
HankL69's Avatar
Engine: 5.0 / 350
Put a salvage yard cluster with 95k miles on it and no differance so I think I can rule out the cluster. That was the first thing I tried.
Thanks for the input.
Old Aug 16, 2010 | 07:02 PM
HankL69's Avatar
Engine: 5.0 / 350
OK, Got in the van yesterday a.m. just to move it so I could get my car out and noticed that the speedo seemed to be working. So I took it down the road a mile or so and guess what! Now it is working just fine. It has been very humid here for the last week or more. Could that have any effect on the electronics? At this point I don't have a whole lot of trust in the truck. Anybody want a real good deal on a '99 Chevy 2500 Express van.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
anesthes
Sep 30, 2015 07:48 AM
