headlight switch
Old Aug 20, 2010 | 11:03 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
headlight switch
hey, i have a 83 berlinetta with the regular dash cept it has 2 needles on one gauge (kph & mph) but at night time when my headlights are on, the dash is barelyyyyyy lit up. if i swivel the headlight dimmer **** it doesnt do anything..should i replace it or what could be the prob.? im thinkin of puttin LED'S in the dash, but are they costly?
Old Aug 24, 2010 | 09:06 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cheep Trik
Nope, you can get LED replacements for only 79¢ each.
However you’ll still have to address the dimmer problem.
At the very least you’ll have to jump the rheostat so you can light the LED’s fully.
Happy Racing!
Engines Run Best Right Before They Blow Up
Old Aug 25, 2010 | 02:20 PM
LeftyGuitar91's Avatar
Car: 1991 Firebird Formula
Engine: 5.7 V8
Axle/Gears: Richmond 3.73
Re: headlight switch
yes LED's are pretty expensive. I am redoing my interior dash lights with LED's also and a pack of two at pep boys is like 7.99. what NINA is probably talking about are replacement factory lights, but LED's are costly but they look great. I personally have blue and I love them
Old Aug 25, 2010 | 04:36 PM
vinny83's Avatar
mmm ok. ill prolly just get new replacement lights, but i think my dimmer might be bad as well, they light up only sometimes when i turn the ****.
Old Sep 5, 2010 | 02:38 PM
johns88z28's Avatar
Car: 88 z28
Engine: 350 jegs crate motor
Transmission: 700r4 b&m transpak and megashifter
Axle/Gears: stock posi 3.23 disk brokes
common problem dimmer should be les than $20 at local stores
johns88z28's Avatar
Car: 88 z28
kinda hard to replace the dimmer
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
