A question in reguards to wiring...
Old Aug 26, 2010 | 10:40 AM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
On my 1989, Pontiac Formula.
1. What is the relay that is mounted on/by the fender (Passanger's Side) , close to the coolant resivoir, by the charcoal canister?
2. What is the relay mounted to the radiator frame (Passanger's Side) ?
3. When I remove the key from my car it makes a Beep, Beep, Beep, Beep, sound. Did these cars come with some type of factory alarm? I hear it coming from the speakers, maybe not to sure?
The battery has been relocated to the back.
So there's some type of starter switch back there, how come?
Old Aug 26, 2010 | 11:15 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Beeping But Horn Is Not Blowing
If the beeping IS coming from the speakers, and not just the Audio Alarm Assembly that is a PO mod.
Auxiliary rear starter button (if it’s not actually a disconnect) could be for some type of convenience while maintaining the car.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Old Aug 27, 2010 | 09:45 AM
Re: A question in reguards to wiring...
How do I check if the sound is coming from the Audio Alarm Assembly? What is the Audio Alarm Assembly?
Old Aug 29, 2010 | 03:22 PM
Well those two relays seem to be hacked up, re-wired, and some type of power distributor is linked to them. please help!
Old Aug 30, 2010 | 12:04 PM
NINÅ's Avatar
Transmission: 765R4
You need to remove the PO added devices.
When you see a PO added device spliced into 2 wires of the same color and gage you can splice those.
You can temporarily put a fuse inline if you’re unsure.
Check pin D of the Audio Alarm Assembly to make sure it’s not being shorted to power.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Sep 1, 2010 | 06:37 PM
Can somone take a stab at the two relay's???
Old Sep 4, 2010 | 11:12 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Usually I believe the fuel pump relay and the coolant fan relay. I got some wiring diagram copies from the library. They show the colors of the wires and that can help sort them out.
Sorry I was talking about the ones by the firewall drivers side. I thought the ones in the front were the aux cooling and horn relay, but i could be wrong. There is a fuse holder for the starting circut up there too.
A picture may help.
Old Feb 26, 2015 | 02:20 AM
HA!
Turns out it's the ancient Sony Head Unit, the beep is reminding me to remove the Faceplate....
Ahhh Technology!!
Old Feb 26, 2015 | 02:22 AM
Only Took Five Years to Solve this Mystery...
Old Mar 28, 2015 | 08:09 AM
Mod '85 Z's Avatar
Car: '87 IROC Z
That's a riot!!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
