New IAC install
Old Aug 29, 2010 | 07:12 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
New IAC install
I am little confused, do I have to the the IAC adjustment when I install a new IAC?
Old Sep 1, 2010 | 08:58 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: New IAC install
I think it would be a good idea...
Old Sep 1, 2010 | 09:03 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: New IAC install
if you mean that by the way of jumping the 2 terminals on the diagnostic connector to put car in diagnostic mode, waiting 30 seconds, disconnecting the iacv and set timing connector, then start the car, remove the jumper wire, or paperclip , and set it by turning the idle screw to increase or decrease rpms, then maybe. Id install it, and see how it idles first, if its good, then dont mess with that procedure, thats my honest opinion. (Id double check on the exact steps, havent done it in a while)
Old Sep 2, 2010 | 08:53 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
Re: New IAC install
Yes by everything you said, i guess i didnt want to mess with the idle screw, the car idle pretty well until it got to operating temp. so i will try installing it and running it without messing with the idle screw.
Old Sep 2, 2010 | 09:03 PM
Stephen's Avatar
Car: 87 GTA
Re: New IAC install
I've replaced mine twice (first one fell apart) & never adjusted anything & no worries afterwards.
But if your gonna get a new one anyways, go ahead & do this.....
IAT Upgrade & Relocation
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
mdtoren
Aug 16, 2015 05:45 PM
