Covan gauges -autometer
Old Sep 1, 2010 | 06:41 PM
Guest
Guest
Posts: n/a
Had my mechanic install a gauge cluster in my '87 IROC-Z. Everything works great but no cruise control (which worked perfectly before). Decided to get this sorted out when I took the car out this summer. Went to my other mechanic at GM dealership - says everything hooked up like it should be but no cruise control. A solution would be welcome AND appreciated.
Old Sep 2, 2010 | 01:10 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruisin’ For A Diagnosis
OK so IF the GM “highly trained professional” is correct, it means the stalk, Cruise Module or servo is defective, or there is a vacuum leak.
Because you had someone else do the dash, it sounds like you don’t work on your car(s) yourself.
Tell Mr. Goodwrench to look again at the connections, and this time carry a meter with him to take a few measurements.
It will take only 9 minutes.
Happy Racing!
Does The White Flag Mean He’s Surrendering?
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
