electrical starting issue?
Old Sep 2, 2010 | 03:25 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
87 chevy camaro 2.8 v6 manual.. starter and solenoidare good.. fusible links are getting power on both sides of wires.. purple signal wire is getting power at crank. battery checked out as bad at pepboys yet the horn blows loud the lights are bright and everything seems as if they are running at high power.. fuses under dash are good. ...it only cranks when it feels like and it doesnt even click when it doesnt start.. i heard that when the clutch start switch is unplugged you can crank it without putting the clutch to the floor. what could it be? can a battery really be that bad?
Old Sep 2, 2010 | 04:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: electrical starting issue?
Starter draws alot of amps - horns, lights, etc don't draw alot - so they can function great with a bad battery. Voltage isn't an issue - it's amps. Plenty of batteries with bad cells, corroded plates, etc. will run lights and not starter.
Old Sep 2, 2010 | 06:18 PM
Axle/Gears: 3.47
oooo.. ok. il get a junk yard batt cuz money is tight.. n il put it in n checkit out.. if something turns up il message
Old Sep 2, 2010 | 06:49 PM
Car: 1992 RS
Engine: Carbed 350
How old is the battery? Might still be under warranty, although they won't replace it for free (battery warranties are usually prorated). And if it's too old, it's probably bad for sure.
Old Sep 2, 2010 | 07:34 PM
Axle/Gears: 3.47
no idea.. i bought the car 3 months ago not running.. the battery was dead when i bought it. and charged a couple times until i got the car running.. found out it needed a timing chain.. battery sat for 3 months dead.. just got the timing chain done and starter went.. replaced starter.. starter cranked like 5 times then no click nothin.. wires r fine by the starter.. took it to pepboys said it was bad... idk where the battery was bought from
Old Sep 3, 2010 | 01:07 PM
Axle/Gears: 3.47
battery is changed.. car cranked 2 out of 2 times.. so i hope those3 2 times arent when the casr felt like starting and it accually is fixed.. i just gatta do the timing
Old Sep 3, 2010 | 09:43 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
check the relay by the drivers side kick pannel. there is a relay there. use a jumper on the big 2 wires on the relay. im sure it will start. i had a simmilar problem last week. still have to trace down the issue but it should start.
Old Sep 5, 2010 | 11:15 AM
Axle/Gears: 3.47
what exactly is a kick panel? im guessing its the panel that the hood release is by?
Old Sep 5, 2010 | 11:52 AM
Car: 1992 RS
Engine: Carbed 350
Yes, that's it.
BUT ... YOU don't have a relay there - that was only on VATS cars, and you don't have VATS.
Old Sep 5, 2010 | 12:36 PM
Axle/Gears: 3.47
yeah.. i took the junkyard battery to conway and they said the battery is weak but with a jumper cable on it the car should atleast attempt to crank...its doing it again.. so it has to be electrical.. someone walk me through every single thing i have to test.. the signal wire is getting power so im guessing everything b4 that is good... but the atsrter is also good.. its sitting on clean metal so its grounded well... im really starting to get angry....unless someone wants to come over and check it out for me lol
Old Sep 7, 2010 | 09:46 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky ▬ So You Are
You said the purple wire gets power when you try to start.
Connect a lightbulb across the
purple wire at the solenoid and ground.
If it lights when you try to start, but no cranking, you have a bad connection immediately adjacent to the test lightbulb connection, or the starter is bad.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Sep 7, 2010 | 07:52 PM
Axle/Gears: 3.47
Re: Car Is Not Cranky ▬ So You Are
i feel stupid because i read that statement 5 times and didnt really understand it....the wire got juice but it doesnt crank.. that means that i have a problem where?...every batt i got out of the junkyard was bad.. even this new one i just got.. but i put it in and it immediatly started cranking easily.. and eventually it started doing it again... its gatta be a battery.
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
