speedo help! i go over 140mph everywhere i go!
Old Sep 2, 2010 | 09:10 PM
kyleiroc88's Avatar
Car: 88 iroc-z, 86 trans am
Engine: lt1
Transmission: 700r4 tci streetfighter
Axle/Gears: '02 10 bolt, slp auburn diff
ok so i have an 86 bird. originally equipped with a t5. had an electric sending unit for speedo and had an 85mph speedo. i swapped in a newer 700r4 with electric speedo. at the same time i swapped in a 140mpg speedo. now 20mph is 140mph! you should watch the odometer turn! how do i fix my problem???
Old Sep 2, 2010 | 11:01 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: speedo help! i go over 140mph everywhere i go!
I believe there is a speedo box under the passenger side dash that translates the signal from the tranny. I know that signal has changed a bunch of times over the years. Do a search along those lines and you will probably find what you are looking for. Sorry I don't know more.
Old Sep 3, 2010 | 12:01 AM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Hey boss, got a number for you to check this guy out! He helped me with
my Richmond 6spd, and now this new Magium T-56 I have now...
His name is Roger, the place is Speedo Service.....# 414-463-6660...
Maybe he can tell you where to look....knows his speed-O's
good luck
Old Sep 3, 2010 | 12:47 AM
kyleiroc88's Avatar
Engine: lt1
cool thanks!
Old Sep 3, 2010 | 09:48 AM
kyleiroc88's Avatar
Engine: lt1
i spoke with roger. he said to pull off tail housing and cut off wheel and replace with speedo gear and new sending unit. sounds like a pain in the ***.. and not the cheapest. i think im gonna try something different that will cost me like 5 bucks. im gonna grab a 92ish vss buffer box and hook it up in between the speedo and sending unit. then i can put a dip switch in it and change for rear end gears and tires easily. is an 86 speedo a direct swap with something newer like a 92? if so i see no reason why this would not work. i had a 96 pickup someone scrapped the computer in and carbed it and it had no speedo. i grabbed a vss buffer off a 94 put it in and it worked great
Old Nov 14, 2010 | 03:16 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
I'm late to the game here but I had the exact same problem. I put in a new 700r4 that came with the metal 40 tooth relucter wheel on the output shaft. That is for a newer vehicle that has anti-lock braking and puts out abot 10 times as many pulses per revolution. I could have done what you suggested and beat the 40 tooth wheel off and install the plastic gear with matching sending unit but instead i removed the tail housing and ground down 36 of the metal ridges leaving 4 equal spaced ridges. That worked out to be pretty close for my tire size and rear gears. From there you can change the calibration if you have the ability to get it dead on, but mine was only a couple mph's off. You need to do the do the math to figure out drive shaft rpm's in a mile versus the speedometer rpm's in a mile, usually either 1000 or 4000.
Old Jan 23, 2016 | 09:55 AM
kyleiroc88's Avatar
Engine: lt1
The newer vss does work btw
Old Jan 23, 2016 | 10:55 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Wow! Long time between posts but glad you got it all figured out. Does the speedo work properly? Did you have to take the tailshaft out? I think in '91 the buffer box was incorporated into the ECM, or that is what I have read. Give us a little more information on your fix.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
