305 TPI hei Distributor work on a Carbed 350?
Old Sep 6, 2010 | 12:22 AM
BDKerr11's Avatar
Car: 86 Transam / 80 Transam
Engine: 86/355 lo5 80/68' GTO 400
Transmission: 86/700R4 80/TH400
Axle/Gears: 86/3.42
I replaced the 305 TPI H.O. in my 86 TA with a 350 lo5 with aluminium l98 heads and a zz4 roller cam, edlebrock performer intake and 750 carb. is there any way I can use the 305 tpi distributor in the 350? I know its a computer controlled distributor but what sensors control it? Ive heard it was the knock sensor. if I just hook up the the oxygen, knock, & heat sensors will it run properly?
Old Sep 6, 2010 | 12:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 TPI hei Distributor work on a Carbed 350?
It would be easier to just replace the distributor.
Old Sep 6, 2010 | 02:20 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
That's a 10 - 4 you need A centrifugal Distributor..
Old Sep 6, 2010 | 03:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by BDKerr11
is there any way I can use the 305 tpi distributor in the 350? I know its a computer controlled distributor but what sensors control it? ?
No
the computer controls it from inputs it sees from all the EFI sensors inc the TPS which you won't have on a carb
Old Sep 6, 2010 | 09:57 AM
BDKerr11's Avatar
Axle/Gears: 86/3.42
Thanks I figured that was the case and was gonna buy one with vacuum advance but once I get my TPI redone I was going back to fuel injection and hoped I could just use the tpi distributor intill then.
Old Sep 6, 2010 | 11:50 PM
88gta3508's Avatar
Engine: 231 / 383
what was the plan for fuel... from a 40Lb + system down to 8lb
Old Oct 15, 2010 | 12:07 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Originally Posted by vetteoz
No
Not exactly true, CCC Q-jets have a TPS, but I do see where you are going - and OP, no it won't work if your not using electronically controlled timing anymore.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
st.evel07
Aug 13, 2015 06:15 PM
stalkier
Aug 7, 2015 04:49 AM
drathaar907
Aug 6, 2015 04:20 PM
