electronic spark controll module
Old Sep 8, 2010 | 11:51 PM
polaris91's Avatar
Car: 88 camaro z28
any ideas on where i can find one? or is there a way to test if it is bad? because my car keeps throwing codes 42 and 43 i was told to try changing the knock sensor but that diddnt fix it. my boces teacher told me to try changing the esc module but i cant get it from work (advanced auto parts)
heres a previous thread i had
https://www.thirdgen.org/forums/tbi/...s-42-43-a.html
thanks for any help guys
Old Sep 9, 2010 | 02:12 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: electronic spark controll module
I'm having the same issues, Code 43 here. Any help would be greatly appreciated!
Old Sep 9, 2010 | 06:34 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Autozone shows one at $50+ but I think you'll find that the ESC is not the problem, it's a pretty hardy piece. But if you want to try a used, known good one, I can send you one for the cost of shipping, maybe $5?. I have one or two from some 305 to 350 swaps. It'd be next week before I could send it though, I'm out of town through the weekend.
Are there any other symptoms? Does you tach bounce?
Old Sep 9, 2010 | 10:54 AM
polaris91's Avatar
Car: 88 camaro z28
no tach bouncing the only other issue i was having with the car was that whenever the car would warm up ( after a cold start) the rpms would jump up about 5-600 rpm and the engine would rev. and that would be awsome but the motor is out of the car because it was crashed and i think the problem i was having contributed to the crash. im going to be using this motor to put into the new chassis i bought but i want to make sure any problems are fixed with it before i put it in the new car
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
